Jeep JK 50" Light bar mounts at Motobilt.com
motobilt
Official Vendor
Jeep JK 50" Light bar mount at Motobilt.com
The Jeep JK 50" LED Light Bar Mount System from Motobilt was designed with function and form in mind. Often time people are puzzled on where to run the wires for the light bar and hide them from sight. When designing this bracket system this was addressed. We spaced the mounts out slightly to allow room for the wiring harness to pass behind the brackets. We do not provide wiring instructions for the LED light bar. The brackets are laser cut from 3/16" steel plate and formed on a hydraulic press brake. They not only provde a solid mounting point for your LED light bar they also provide protection for the a-pillars of the windshield frame.
Our Jeep JK LED Light Bar Mount only comes in contact with the windshield mount. They do not come in contact with the windshield frame and a rubber gasket is not needed. The light bar mounts are shipped bare steel for you to paint or powercoat. We ship them this way because so many people want to color match their Jeep JK.
NOTE: THIS LIGHT BAR MOUNT IS DESIGNED TO FIT LED LIGHT BARS WITH A MOUNTING WIDTH OF 50-1/4". THIS LIGHT BAR MOUNT WILL NOT WORK WITH RIGID INDUSTRIES 50" LED LIGHT BAR OR OTHERS WIDER THAN 50-1/4".
FEATURES
Laser cut 3/16" steel plate
Designed for LED lights with a mounting width of 50-1/4" wide
has room to run wiring harness behind the bracket
Keeps the top of the LED light bar below the roof line for a tight fit
Includes hardware
LED LIGHTING IS FOR OFFROAD USE ONLY
