Jeep Liberty speedometer
03jeepliberty03
I am having a problem with my speed sensor. Changed the transmition output no luck. Changed the rear speed sensor 4 times still no luck. Checked the wire by the emergency break, All wires are fine. Don't know what is going on. Any one know what's to do?
thanks!!
The speed sensor likely has to be turned in the mounting hole to correctly 'clock' it, that is turning it until the speedo gear engages the gear on the shaft inside the transmission/transfer case.
Look for an alignment mark around the hole where the speed sensor is mounted, and align it with the correct markings on the speedo gear.
