i have a 2003 jeep wrangler sport.i installed two red led 1157 taillight bulbs.everything works,but the right side flashes fast,as if a bulb were out.i know that this an issue of less resistance than an incandescant bulb.i did some online research,and everything points to either install ballast resistor,which gets hot,and scares me,or modify the factory flasher(looks like a pain in the arse),or put an ep-27 flasher in.i installed the ep-27,and everything was fine,up until i hit the hazard flasher switch.then i suddenly have nothing.found a blown fuse under the hood and replaced it.also put old bulbs back in until i get this sorted out.surely someone besides me has had this problem!any help or advisement would be greatly appreciated!
