Baseline 4x4
18676.60 - Rugged Ridge SYE Slip Yoke Eliminator Kit, Np231, 87-95 Jeep YJ Wrangler, 97-06 Jeep TJ WranglerThis Slip Yoke Eliminator Kit is designed to fit 1987 to 2006 Jeep® YJ and TJ Wranglers with the NP231J Transfer Case
The model NP231 transfer case is a compact, chain-driven transfer case manufactured by New Venture Gear (New Process Gear) in Syracuse, New York. Since the early 80's, the model 231 has been used in many vehicles and is designated as follows: NP231C = GM S-10, S-15 trucks & Blazers 1983 - 1991, NP231D = Dodge midsize and fullsize trucks, NP231J = Jeep YJ's, TJ's, and some XJ's. This transfer case was first introduced in Jeep Wranglers in 1988 after replacing a 1-year run of NP207 transfer cases.
All "J" models of the NP231 are not created the same. There are internal differences among different year models and this kit has been designed to be compatible with each version. Our fixed yoke kit has been installed in hundreds of V8 equipped Wranglers (small block and big block) to date without a single shaft failure. Because of this success, the new output shaft carries a Lifetime Replacement Warranty.
We also have a Rebates up to $200 on Rugged Ridge, Alloy USA, Precision Gear, Outland. Click Here for details
