knock knock
96 XJ here, 180k 4.0. Recently I've had a repetitive knock sound show up. You don't hear it on a cold start but after it warms up there's a distinctive lower pitched knock with a frequency of about 10 times a second, at idle. Seems to be coming from the bottom of the car/engine as you can hear it better from the sides and rear. The normal engine sounds seem to drown it out when you listen from over or in front of the engine. Not sure if the knocks increase in frequency along with acceleration.
Any ideas?
Loose exhaust- pipe banging oil pan.
Leaky exhaust at a cylinder - #5 or 6 exhaust bolt comes loose.
Broken piston skirt
