Leaf springs
Whips 17
Hi. I need my leaf springs on my CJ-7. I have LOA lift. Should I look for a lift package or factory ones. Thks
I think he saying he has leafs over axle, SOA (springs over axle). If this is the case you need a good set that has military wrapped springs Full eye-lets, due to some spring warping.
If going spring over you can use a set of factory YJ springs. You will have to change the front and rear spring mounts to accommodate the wider springs.
