Leaking clutch
The clutch master cylinder is probably leaking from the piston into the cab. Replacing the clutch master cylinder should do the trick. Make sure you bleed the system well after replacement.
I'm not sure what type of Jeep you have, but I've moved your thread to the Wrangler section
