Led turn signal mirror wiring help
4ren6
Recently bought a great looking set of replacement mirrors with turn signal led and side floods that can be manually used by toggle.​
I own a 2015 Jeep Wrangler sport. I do not have electric mirrows or wiring within the door panel. The unit has three wire white ground which I can ground to door itself along with red and black. Also two types of toggle switches for led side floods to use as needed.
Question is the set up is for those that have electric mirrow thus a simple plug and go. Mine with no wiring is going to need to be routed different. Do I run straight to turn signal lights or can I tap into something such as a fuse or relay on turn signals. My understanding is there is no relay for the turn signal as it's all run through the mother board. So I have 3 wires to get this going. Suggestions on how to proceed appreciated. Never been electrical Davy !! Again I have mounted mirrows and for now just tucked wires inside door wall.
