Looking at a jeep cherokee, what do you think?
bono
hello,
i am new to the board, i am in the hunt for a jeep as we speak. i came across this one. i saw it today. it is clean in/out. it has a recent overheating issue. but it says it has an aux. fan switch. i did not have enough time to find the switch and see if it would bring the temp down. i dont think the current owner has a clue. anyway, it seems pretty good, i would appreciate y'alls opinion. i have posted the add below. thanks!
1988 Jeep Cherokee XJ Laredo
4.0 Liter, Automatic, 4 Door, 4WD, 164,000 Miles,
Power Windows and Locks, Cruise Control
Extras:
4.10 axle gears
Dana 44 rear axle
ARB air locking differentials front and rear
ARB air compressor with tire inflation kit
Heavy Duty rear CV style drive shaft with slip yoke
Slip Yoke Eliminator on transfer case
Bomb-proof engine mounts
6 inch lift:
Rubicon Express 4.5 “ Super Flex Lift
Adjustable upper and lower control arms
1.5” inch coil spring spacers
1.5” lift (3 Inch) extended rear shackles
Rancho 9000 shocks
Rubicon Express heavy duty adjustable track bar
JKS Bar Pin Eliminators front and rear
JKS Quicker sway bar disconnects
Custom (Tomken style) heavy duty front bumper with receiver
Tomken rear bumper with tire carrier and receiver hitch
Confer roof rack with high lift jack mount and spare tire mount
Rusty’s air tube with K&N filter
Transmission cooler
Flowmaster muffler
Heavy Duty Grand Cherokee (ZJ) tie rid and drag link
JP Boulder Bars
Differential cover guards front and rear
Gas tank skid plate
Transfer case skid plate
Extended length stainless steel brake lines
2nd gear selector switch
Auxiliary fan switch
Optima red top battery
Driving Lights
Steering brace
Rancho 5000 steering stabilizer
Extended bump stops front and rear
Undercarriage Lights
CB radio
High power Kenwood CD Player with remote controls on steering wheel
Alpine Amp
Large Truck speakers (rear)
Sony door speakers (front)
Alarm System
July 2006 New AC compressor
August 2006 New 33” BFG All Terrains
August 2007 New Fuel Injectors
Spares:
Spare Dana 30 axle shafts with u-joints installed. Spare tie rod and drag link
$27,000 invested
$4,000 obo
Overheating issues can be addressed. We can help you out with that. You'll have more time to search for that auxillary fan switch after you buy it. If that's your only concern and, as Bounty said, if it's rust free (even mostly rust free), I'd seriously consider making that purchase. Welcome to the Z.
WOW! yeah if you like it and its rust free or rust a little and you can fix it get it. The fan wiring is a snap and it will be useful on the trail since you will be pulling up hills and keeping a slow approach which tends to heat your plant up a bit.
