more lift
dbr5010
I just got my 2in body lift on and i got a shackle replacement . The shackles do not add alot of lift but a little will i have to do anything to the drive shaft if i add a 4in sus lift later. I dont want to add an sye right know what do you think.
This on a YJ?
You'll need to lower the transfer case with a 4" lift unless you do the SYE. The shackle lift and 4" springs may cause some driveline vibes if the pinion angles aren't correct. Most 4" kits figure thier degree shims with stock height shackles in mind.
I still have the old shackles would it be better to put them back on with the 4in sus? when get the lift i will be out of money and the sye are about 250 so i am trying to get by without it.
try it with them first. They are easy enough to swap out.
Its the same kind of set up that I had the vibes are not to bad.The only problem that I found is when I dropped the case your skid acts like a shovel.Sye and a flat skid then your good to go.
