1062892
k-phat, i did mount a set of lights on the windshield bracket or hinges is what they are. i did run the wire under the windshield frame rubber. only had to run one wire across and connected to the other light outside the gasket. worked fine for me.
tug, i mounted two sets . as i said above on the windshield bracket, but i made my own mounts . used a pieace of stainless and cut them the same shape and angle of the windshield bracket. painted them black with some epoxcey (help tug ) . i used the stainless because that is what i had on hand. i have not had any problems with glare, from the hood or windshield. the ole yj is black but still would do it again. also have a set mounted on the front bumper. those i mounted as far apart as i could and still mount to metal. not so sure i get the effect as if they were closer together. maybe someone else can shed light on this. (was that a pun ? )
if there is one thing i have learned from my yj is that if i dont like it i can go back and change it with out to much hassle . dosent mean i like to do it twice , just i try it one way let it settle and if i dont like it i can change it . just my opinion......odax :-D [addsig]
