Need quick help.
CherokeeGuy42
Ok my driverside brake light and turn signal don't work. I don't know what I should look for to fix it. The bulbs look fine so I'm stumped. The driving light and reverse light work fine just the other 2 don't. Any help? Thanks
Take the housing out. Check the plugs themselves, it could be corroded. Also, the wiring harness can play a role in this, but since its on one side, I doubt it. There might be some plugs for the lights near the quarter panel inside the front door. I lost my brake lights on my 95 and saw a plugs half connected by where the feet rest.
Need help deciding which Jeep to Keep
Does the driver side front turn signal work OK when the rear doesn't? If it doesn't, it could be in the turn signal switch. LBR
I went and replaced all 3 bulbs and it works now. Turns out apparently I needed all 3 bulbs in the taillight to work before the brake light and turn signal will work, but the parking light and reverse light don't need all 3. Any ideas on why that happens?
