cr125racer
i have a 1990 wrangler with the 2.5 5 speed with a drivability problem. it idles fine, but when you go to pull out it stumbles. i replaced the cap, rotor, plug wire and plugs. i noticed a slight change but still not good. when i pulled the plugs, they had a lot of carbon on them. checked feul preasure and it is good. checked timing and timing is running at 12 degrees BTDC. not sure what timing should be, and timing is non adjustable. any ideas. thanks mike
could it be a weak ignition coil?
