Liberty head gasket question
Hello, I'm a newbie so if this is a repeat question/post I apologise in advance. I bought a 2008 liberty Limited 4x4 from a co-worker who bought it new and his daughter had been driving it, apparently it overheated a couple times with her, it was losing coolant but no visible leaks. They took it to a mechanic who said that the thermostat was stuck open and a head gasket was bad so they parked it. I drove it about 50 miles home after topping it off with coolant, it never overheated but I did see some steam once while stopped at a traffic light from the area of the grill. I flushed it out, noticed that even after letting it idle for about 45 minutes with the heat wide open that it wasn't blowing hot, but the heat works great while driving. Is that a thermostat issue? Water and oil is not mixing, I've drove it a couple times just to see if it would overheat but it hasn't. I'm wanting some input from the experts in which path to take. Since the water and oil isn't mixing and it's not yet overheated with me, not blowing warm air at idle but does while driving what's the best plan. It has 183000 miles on it
