No start
mhoran
This morning I went to start my '01 Wrangler and there was a 3-4 second pause with no cranking before the starter kicked in and started. It did not occur when I started it after work, but my check guage light came on and my battery needle was swaying back and forth between 9 and 15. I have never seen this. Any help in explaining would be great. Thanks.
Could have bad connection at batt or starter.
Re: Problem starting
Check your grounds and be sure the terminal connections are cleaned. Get your battery load tested. The winter’s cold temp helps point out failing batteries. And a loose connection or dirty one will cause issues.
I had a symptom on my F150 like this. The alternator brushes wore down and shorted together. That alternator had a cartridge type brush set you could pop in and out. I don't know if you alt is like that but it is something to look into.
Thanks guys, I'll check those things. It hasn't been too cold here in CO this winter, but maybe it is time for a new battery anyways.
After checking the connections, have your battery and starter checked. BTW, i moved your thread on the jeep technical forum.
