allabs5150
Ok not to wish any misfortune on anyone, but i hope someone here has encountered this problem cause I am puling my hair out trying to figure it out.
Jeep in question is 87 yj 4.2 manual transmission.
Problem:
I have not ruled out the possibility the problem could be the Weber carb set up which although I was never 100% happy with was much better than the stock junk the jeep came with.
When driving the jeep once I get out of first gear the problem occurs once I get close to 2,000 rpm the jeep acts as though its not getting any fuel and sputters till I shift into the next gear, again once I hit aroung 2K rpms in 3rd 4th & 5th gears the problem arises. Now I can still drive the jeep with not much of a problem as long as I dont throttle the thing up, which is sometimes a problem when driving busy roads.
Now thinking it is a carb issue I just picked up a newley rebuilt MotorCraft 2100 which I have not installed yet, only because I notice the problem seems to almost totally go away when the Jeep has a 1/4 tank or less of fuel in it, and once I fill the tank anywhere over 1/2 to full the sputtering gets so bad the Jeep is not driveable.
Now I am wondering if there is some kind of fuel pick up issue????, or the fuel tank is not venting right?????? or if there is a float in the tank that goes haywire once the tank is full of fuel???????.
Now like I said it's not like the problem never happens when the Jeep is almost run dry on fuel, but it ALWAYS happens when it has a 1/2 tank or more of fuel which is kind of making me think its NOT a carb problem.
Any help is greatly appriciated as I am running out of hair to pull out
Problem:
