Oil Burning
Jeepz4Mee
For some strange reason I have oil burning from my 95 YJ. I cant seem to put a finger on what it is. I can smell it coming from the exhaust when ever I have the back window open. I recently added an Air Raid Intake and a 62mm throttle body spacer. Could this be the issue? Also, how do you know when a oxygen sensor goes out? Seems like I am burning too rich. One more question, my second gear seems to be catching a little bit. Dont know what could be causing that either(maybe the synchro rings), but i just had those replaced not too long ago. I checked the clutch fluid level filled it up and bled the line, however, still no fix. Could this be a trans problem?
Thanks ahead of time,
95 YJ
Details:
1. Air Raid Intake
2. 62mm throttle body spacer
3. 2.5L engine
4. AX-5 transmission
What fluid are you running in the transmission?
If we can get you to run the right fluid soon, it may not be too late.
For the AX5, the wrong fluid is specified in the manual; I STRONGLY recommend Redline MT90! My jeep shifts SO much better after I put that in... It's not even funny! (before I could barely get 1st gear in when standing still!).
