Yes, ZDDP. flat tappet cams need ZDDP (ZINC) to servive, most modern cars are running roller cams and dont need the zinc like the older cars did with their flat tappet cams. Valvoline racing oil has the most zinc that I have found, or rotella motor oil for diesel engines, either is about $5 a quart. I just put a cam and stuff in my motor last spring and comp cams recommended 5w-20wt, I have more engine than you but both are older engines and would benefit from the same. Without running the ZDDP you risk a high chance of wiping out a cam lobe quick. Modern oils dont have the zinc like they used to because the roller cams in newer cars dont need it.
