Why only when warm?
I read of 07-12 window issues. Some people turn the engine off and back on and the issue resets and the window starts working again.
Others state resetting the PCM works, but I don't see a module in the wiring diagram just switches. My Honda has a module and freezes once in a while so auto up and auto down doesn't work until you reset the module. I don't see that anywhere for the JK.
If there is no module then it is either switch, motor or connection.
Regards,
JPNinPA
Sent using TapTalk
