Hello all. I'm in the process of putting together parts for a build on my '06 TJ and I'm looking for some advice. Currently I have a 2" RE budget lift and 32" Mud Terrains. For reference, I have the stock Dana 30 front and stock non-Rubicon Dana 44 rear end.
I guess the best place to start would be to tell you my plans and see if there is anything you all might disagree with or think I should do differently.
My goal is to clear 35" tires and be able to run "Black" trails without issue. Also keep in mind that while my Jeep is NOT a daily driver, I still want to keep it pretty comfortable on the road as well. To that end, here is my current thinking:
1) Upgrade to 4" short arm kit. I already have 4" Skyjacker springs and shocks (maybe not the best but I already bought them so I'm going to have to live with it). I plan on purchasing a full set of control arms from either Rough Country or Rusty's, all adjustable with flex joints. I also plan on adding adjustable track bars. I still need to pick up extended brake lines in addition to all of this, and I'm going to add a Skyjacker steering stabilizer while I'm at it.
2) Upgrading to the 4" lift, I'm going to go ahead and bite the bullet and upgrade to a SYE instead of another transfer case drop. I figured since I'm going to mess with the transfer case anyway, I might as well do a tummy tuck, with a high clearance transfer case skid. My research into this indicates that this will probably require a 1" body lift, so final lift count is 4" suspension + 1" body lift. Will this adequately clear 35" tires?
3) If I'm going to run 35" tires, the gearing charts I've looked at say that I won't be very happy with my stock 3.73 gears, so I plan on going with some 4.88 gears. If I'm going to be pulling my diffs apart, I might as well get some lockers, right? Those will come in handy on the black trails anyway . So I'm thinking I'd rather have something that locks positively as opposed to a limited slip, and I've been looking hard at OX lockers, since it appears that their pricing is competitive with ARB and I would not have to worry about messing with an onboard air system at this time. Since I'm planning on doing all this anyway, I might as well upgrade the axles, so I'm toying with the idea of upgrading from 27 spline to 30 spline axles in the D30...not sure if it would be worthwhile to upgrade the D44 or not. Thoughts?
So anyway...this is something I'm going to be working on gradually over the next year (or two...or three ) but I've given it a lot of thought and I think I have a good plan. Now it's your turn to tell me I'm an idiot and why I shouldn't do this and/or where I've screwed up.
