The reverse eye just makes a more durable spring...both in sua and soa, and should yield good flex in both applications. It's not necessary in a sua setup, but won't hurt. The fixed spring hangers on CJ's are already wide enough to accomodate 2.5" springs even in the front, if you look at the bushings on the back of the front springs you will notice that they extend an extra .5" on either side of the spring, where if you were to use normal bushings you could use YJ springs in the front without modification. All you need are those special shackles that RE makes, or you could even move those extra wide bushings to the front shackle hanger and just use a regular 2.5" wide shackle in the front. This would not be as stable as the RE shackles and not a great idea for a DD, but would provide better flex through more lateral movement much in the same way that revolver shackles work.
