Wranglerman21
Hello Jeepers!! Well I have a 2001 Wrangler with a dana 44 which had a leaking pinion seal. I replaced the seal, took the rear diff cover off to change the fluid and put it all back together. I put 75-90 mobil one gear oil back in the diff and sealed up the cover. I changed the pinion seal and when i put the Pinion Nut back on i torqued it down to 210 ft lbs. Im not sure if thats the correct amount. (my haynes books doesnt say OFCOARSE) Now when im going down the road and there is torque on the rear end its got a wining noise, but only when power is applied. I wasnt sure if i torqued down the pinion nut too much wrecking the bearing. Anyone have any guesses??? Help is greatly appreciated fellas!p0p
