Ok so heres my rant....
I changed the oil on my 97' TJ the other day, the next day it wouldnt start.
so i did some troubleshooting and found no pressure to the fuel rail.
I then proceeded to drop the tank and verify that my pump went bad (overnight apparently), so I put in a new pump and filters, reinstalled tank.
Now I have pressure on the rail, but now I have no spark!
I checked and am not getting spark off the coil.
Most likely culprit: Crank Position Sensor....
ok replaced it. STILL NO SPARK!
Ive been told it could be my coil, so I took the one off my XJ and put it in, still nothing.
got told its distributor, did same thing with dist. off XJ, still nothing.
what am i missing? :???:
Did my PCM go **** up?
is there a fusible link somewhere i am missing?
is there an Auto Shut Down or kill switch im missing?
PLEASE HELP!!!! im at my wits end with this Heep.....:crazy:
