Many ford products with a 302 came with a T4 or a T5 transmision and some CJs came with them also. If you have the right bellhousing, It should bolt right up. Have been told that some 6 cylinder bellhousings will fit a V8. You'll just have to move your motor mounts. If you have the AMC 20 rear axle, You might want to consider upgrading that also. It won't last long in if it's in stock condition.
