Sealing up distributor...do I need a vent?
Deerhunter30
I like to make mods on my Jeep based on previous trips. It appears that during water crossings my distributor always gets wet and kills my power. I do not think that I am even submerging the distributor. What I wanted to do is put some silicone around the base of the distributor cap to seal it to the base so water does not get in. My question is, do I then need to vent the distributor? I thought about drilling a hole in it and then glueing a vacuum line fitting to it and running a vacuum line up to the top of the firewall to vent it. Is this necessary? Any advice?
I dunno, but my 4banger's cap has a vent built into the design, it's got a small cap on top that allows air in and out.
Something that I do rather than seal up the distributor is just use a good electrical lube on all the wires both ends and all around the contacts in the cap where the rotor button makes contact. The lube I use is in a .99 cent packet from autozone. I also run a bead of the same lube around the base of the cap where it mounts to the distirbutor itself. This also makes the plug wires pull off easly when you go to remove them. Another thing I have started to do is useinf zip ties I place one around my plug wires in groupes of 2 or 3 going in the same direction then put another one between each of the wires to keep them seperated and off of any heat source. this has proven to be worth the effort in the life of the plug wires. I also use a water displacement silicon spray inside the distirbutor. I find this all to work together to prevent the drowning out problem for me. But the best thing I have found so far is to avoid the mud and water as much as posible when out on the trail. I hope htis all helps a little. As for a vent I have no real answer but if it works for you let us know. tug
You will need some type of vent to prevent condensation if you're going to completely seal the distributor with silicone. You may be able to find a vented cap. If not just use a short hose with a cap similar to those on your rears. I had the same problem with mine. I never submerged any of the ignition system, just seemed to wet out from water spinning off the fan. The electrical spray sealer worked good for a short amount of time but eventually wetted out too. I was going to seal my cap, but started the rebuild before I got around to it. 8)
remember, with lube, you can seal the wires.... but you cannot seal the rotor contacts
I´ve waterproofed a few distributors. The best methode, seemed to be a fine bead of silicon sealer at every seam. The technique that seemed to work the best, was when the silicon was sandwhiched, between the rubber piece and part to be sealed. A dab on the drain hole in the bottom of the distributor, a small bead around where the cap seals and where the cables enter. A small bead around the plug cable distributor towers and on the plugs themselves, about half way down. Where the wire goes into the boot, I also sealed with a small bead of silicon. Same with the coil, high voltage cable.
The down side is when you have a problem, and want to troubleshoot. Cleanup before reaplying, the silicon can be a pain.
I´ve completely submerged, distributors, sealed with this methode and had no loss of spark.
Next best methode is just to seal the distributor with silcon sealer and spary all the boots, with a silicon spray, for rubber (rubber softener/conditioner). Soft cables and boots seal better.
Never had much trouble with, a non vented distributor cap. Vented caps, always seemed to corrode faster than none vented caps anyway. On the 4.0 motor the Ford non- vented cap, seems to last longer than the OEM type jeep vented cap (and was a buck or two cheaper)..
I sealed the cap of my distributor with silicone. My distributor has a breather vent in the top. I pulled the cap off the vent and ran a breather line into my airbox. Never had a problem since.
Hi Deerhunter,
To directly answer your question, I think your distributor, or distributor cap, should be vented for the reason that firemanharry stated.
But, Deerhunter, since you stated that you think the problem is caused by cooling fan water spray, not immersion, I wonder if your distributor drowning problem might be more simply solved by fabricating a spray shield to mount between the distributor and cooling fan?.
If a spray shield worked, you would not have to deal with any "sticky silicon" problems when servicing the distributor somewhere down the road.
Regards,
Gadget
Well I sealed distributor with clear silicone and used a piece of vaccume line on vent ran it up to my K&N intake so the vent stays out of water I sunk jeep a week ago never had an issue also use hose clamp on vent tube to keep it sealed up and use either hose clamps or zip ties to seal all vaccume lines etc and di electric grease on all wire connectors to keep plugs happy
I like it, the only thing I would do different, is to use dielectric grease to seal it. Silicone after a few years of heat, gets very hard to get your distributor off. The dielectric grease is just for that. Put it around any plug, or lamp when replacing stuff.
I have used silicone before.
I have found that di electric grease in water will actually wash out I found out the hard way when I submerged my jeep so I know all to well lol
Wow, I've never had that problem. I pack it around all my lamps, plugs, and cap. I did silicone my cap once. When I took it off, I cracked the cap from prying so hard. With all the heat, silicone gets very strong.
Might as well epoxy it. Heck, long time ago, I made a gasket from a sheet of notebook paper, coated with motor oil. It actually did very well, under my cap.
I'll have to try some of my grease, to see of I can get it to dissolve.
Yeah whatever works for ya I havnt had an issue yet but if your method seals it then that is what counts
I have never bothered sealing my distributor, and I have yet to flood it... Mind you, I have gotten the jeep in rivers about 3.5 feet deep, and still, no issues... Anything deeper than that, and I would be more concerned about the current than the depth of the water.
