93bizzleYJ
i had a new shock mount welded onto my rear axle just before putting my lift on because the old one had broken off, the guy doing the weld used the old shock that had hit the ground hard many times and was probably not the straightest it has ever been, now when i put my new lift on the side that the new shock mount was put on sags a little lower than the other side, could the shock mount angle have something to do with this?? trying to figure out why i am offset here.
-bg
-bg
