Six Cylinder 4.2 Liter Jeep engine Specs - Technical specs
<TABLE cellSpacing=0 cellPadding=2 width="100%" border=1><TBODY><TR><TD width="33%">
Displacement</TD><TD align=middle width="33%">256 cubic
inches
</TD><TD width="34%" rowSpan=11>
Click below to see
the Vacuum curve
</TD></TR><TR><TD width="33%">
Cylinder numbers (front
to rear)
</TD><TD align=middle width="33%">1-2-3-4-5-6</TD></TR><TR><TD width="33%">
Firing order</TD><TD align=middle width="33%">1-5-3-6-2-4</TD></TR><TR><TD width="33%">
Spark Plug gap</TD><TD align=middle width="33%">0.033 to
0.038
Ignition timing</TD><TD align=middle width="33%">9 to 11
degrees
Idle speed (auto)</TD><TD align=middle width="33%">600 +/-
70 rpm
(manual)
</TD><TD align=middle width="33%">680 +/-
70 rpm
Engine oil</TD><TD align=middle width="33%">API SE of
SF
</TD></TR><TR><TD width="33%">- Oil capacity</TD><TD align=middle width="33%">6qts</TD></TR><TR><TD width="33%">
Automatic
Transmission Fluid
</TD><TD align=middle width="33%">Mercon
ATF
</TD></TR><TR><TD width="33%">- ATF Capacity</TD><TD align=middle width="33%">4qts</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 borderColorDark=#999966 cellPadding=0 width="100%" borderColorLight=#cccc99 border=1><TBODY><TR><TD align=middle bgColor=#ffff66 rowSpan=2>
Engine</TD><TD align=middle bgColor=#ffff66 rowSpan=2>
Transmission</TD><TD align=middle bgColor=#ffff66 colSpan=2>
Initial
Timing at
Curb Idle (Vacuum
Hose
Disconnected)
Curb
Idle Speed RPM
</TD></TR><TR><TD align=middle bgColor=#ffff66>
Set
To
</TD><TD align=middle bgColor=#ffff66>
Acceptable
Range
Set
To
Acceptable
Range
</TD></TR><TR><TD align=middle rowSpan=6>258
1 Barrel carb
</TD><TD align=middle rowSpan=3>Manual</TD><TD align=middle>3°
(49)
</TD><TD align=middle>1°
5°
</TD><TD align=middle>850
(49)
</TD><TD align=middle>750
950
</TD></TR><TR><TD align=middle>10°
(Alt)
</TD><TD align=middle>8°
12°
</TD><TD align=middle>600
(Alt)
</TD><TD align=middle>500
700
</TD></TR><TR><TD align=middle>8°
(Cal)
</TD><TD align=middle>6°
10°
(Cal)
950
</TD></TR><TR><TD align=middle rowSpan=3>Automatic</TD><TD align=middle>8°
(49)
10°
</TD><TD align=middle>550
(49)
</TD><TD align=middle>450
650
(Alt)
12°
(Alt)
650
(Cal)
10°
(Cal)
650
</TD></TR><TR><TD align=middle rowSpan=2>258
2 Barrel carb
</TD><TD align=middle>Manual</TD><TD align=middle>6°</TD><TD align=middle>4°
8°
</TD><TD align=middle>650</TD><TD align=middle>550
750
</TD></TR><TR><TD align=middle>Automatic</TD><TD align=middle>6°</TD><TD align=middle>4°
8°
</TD><TD align=middle>550</TD><TD align=middle>450
650
