slave cylinder
TheOKCAggie
I just helped my friend change his clutch in his 94 yj with a 2.5 and ax5. I opened up the master cylinder and it was empty. So I filled it up but I can't figure out how to bleed the slave cylinder. My haynes is no help. It says use the bleeder valve, but I can't find one. Can anyone explain where it is or take a picture and show me? Need to get this fixed so he can start driving it to work again. Thanks.
On the bellhousing, drivers side, follow the hose down from the master. You should find the bleeder sticking out. On mine, it's accessible, but I've been told there are some years that don't stick out and are a real bear to get to.
Some don't have bleeders, you just have to pump the bejesus out of it.
