My local Jeep dealer told me the lowest speedo gear they offered was one with 28 teeth. According to all the charts, I need a 26 tooth for 3.07 gears and 33" tires. Whats up with that?
Its probably right. I couldn't find the right speedo gear for mine either. I ended up getting one from a local driveshaft guy, he keeps all the speedo gears nobody wants. Maybe check around in a place like that.
yeah i guess ill just keep the stock speedo gear until I get 4.11's.
the only problem is the one shop i called wants $500 per axle to swap gears (thats just labor). It cost me $1400 to regear my Ford f150 i used to have and that was from a different shop. So Ill keep calling around i guess until I find a better price. If I dont find a better deal I might be rolling with 3.07 for a while.
My Gibson cat-back exhaust is banging on a bar in the back
Check with jeep for this part number: 52067626
There's a lot of jeepers running 33" and 3.07, until they upgrade first chance they get. I had that setup, but replaced the 258 with a 350, then the 3.07 wasn't so bad.
