I just had the intake man. gasket replaced which fixed a major vacuum leak. No more hissing, coolant leaking, or rough idle, it did wonders. The only problem is now when I start the thing when it is cold, it cranks for a couple seconds, catches and then immediately shuts down. If I keep my foot on the gas for a little bit, it will eventually idle on its own. Once warm, the problem goes away and runs fine.
The mechanic who fixed the vacuum leak said the computer may be recalibrating the mixture since it has had to compensate for a big leak. He scanned it, no codes came back.
Other than the vacuum leak, I have recently changed the fuel filter, plugs and wires, dist. rotor, TPS. I need help ASAP. Any ideas? Thanks in advance for the help.
