Stepmotor
jeepster3
I have 90 jeep wrangler yj, I,m gettingpower to it but after you let it warm up and look down the throte the pin is not moving at all, it's not forword or at the back it just dose not move at all. The jeep idels ok and runs on the highway ok but at idel it dose sputter a little, has anyone had any thing like that if so please let me know.
1040387
You might wan't to see if there are any recalls on that with Jeep. I can't remember if that's what they replaced on my 89Yj or not. It's worth a shot.
1040392
I hate working on those Carters, because you never know if you're going ot make it better or worse (at least that's my case). If there is a problem at idle, I'd try this Carb fix which seems to be the biggest idle problem on those carbs. You could also try spraying everythign with carb cleaner to see if it unsticks.
Terry
