I have an 89 YJ 3.5" lift 31" tires with D30/35 with 3.07 gears. Bought D30/35 from 93 4cly, 4.10s. The problem I have just noticed is that the 89 axles used 3 vacuum lines to work the shift acuator for front axle. Two yellow hoses, one green. 93 has only 2 lines and a wire running to the motor. I did not see the 93 Jeep to investigate. Can I use the axle with this shift motor or should I switch the vacuum shift actuators? Are the axles the same beside this?
