tail lights suck
johnkovarik
So my passenger side rear running light isnt working.
the assembly is fine, everything work fine when plugged into the other side.
There is no power to the wire that powers that running light.
can i splice into the power wire for the driver side to power the passenger side.
Or do i have to run a new wire from the fuse box back too the light.
Sounds like s break or pinch in the wire. A good auto electric shop will have equipment to pinpoint the problem....or, rewire it yourself.
What year model???
On TJ the passenger side is spliced from the driver side near the driver rear.
Trace the wire back.
Verify you have a good low res ground.
