electric fan
Thanks in advance for your help.
My 94 JeepCherLtd-5.2 just came up with a code 24-TPS.
My Chiltons says you can check the voltage on the sensor.
I am completely unfamiliar with checking voltages on a vehicle. Would
standard voltmeter do this?
Also, the book says that you can make adjustments to the TPS by loosening the mounting screws and adjusting it until the appropriate voltage appears? Any advice in going this route before dropping more $ on a new sensor?
thanks a million!
thanks a million!
