track bar
csrobbins
Does anyone know about replacing a track bar in a 98 jeep cherokee laredo. Is there another name for this part. There is a noticeable noise when turning left or right. Cv joints have been replaced and a sway bar arm. Now I'm told the problem is this track bar. thanks for your reply.
770000
if its really your track bar tie rod joint thats croaked then you will here a clunking when you turn right or left without moving forward or backward....if you track bar isnt clunking and you still suspect it as being the prob then replace it not too hard if you have a lift then go while a adjustable track bar like one from rustysoffroad or rubicon express
themud
