CJimd84
Recently swap a automatic for a t5 from a cj I had around they
t he'd up perfect. Only thing I notice was the new transmission happen to be 1/2 smaller in lenght the jeep has a 41/2 lift and the rear drive shaft fell about 1/4 inch short with it fully extended so I installed the screws on the u joint and pretty much tighten it until it mounted . My question is do you think there is to much force pulling on the rear diff doesn't seam to be as smooth as it should any help wil be appreciated. Thanks
