D dbr5010 New member Jan 9, 2006 #1 What transmission will replace a 30rh transmission in a 4cy 95 yj ?
Bounty__Hunter Super Moderator Jan 10, 2006 #3 That's about it, and even then you may have to swap out the transfer case input shaft if the manual AX5 is used. There are some online writeups for swapping in an SM420, try google.
