Hi I was getting a lot of codes and my Jeep went into Limp mode. I cross referenced the codes with possible problems. It’s either at the Transmission Control module (TCM) is bad, the solenoid pack & sensors are bad, I need a new transmission or the fluid/filter are dirty.
I decided to change the fluid, filter and solenoid pack before I took it to a shop for a huge bill. I couldn’t get the valve body to drop and damaged it trying to take it out. I ordered a whole new prebuilt valve body. But stupid rod that goes through the transmission & connects to the bracket the shift cable attaches too will not come out. I Disconnect the shift cable, loosened and removed the bracket attached to the rod. I even removed the washer at the top thinking it could be swollen. It still won’t come down I managed to remove the rest of the valve body from the rod so I know nothing else is holding it in. Is there something inside the transmission that is stopping it from dropping? I know the rod is tapered toward the top but I don’t want to damage the inside of the transmission if there’s something else going on?
I can post some pictures if the would help?
