So, after about 4 hours of wiring and :drunk: I'm about 80% done installing my viper 560xv alarm (I'm not installing the remote start stuff). The last part has me pretty stumped.
There are three options to connect the dome light to the alarm
a + wire
a - wire
a domelight supervision wire
The domelight supervision wire is labeled in the chart below (stolen from the12volt.com), but I can't seem to find it in my jeep. anyone know the location?
Currently, the + door wire is hooked up (I've tried both door pin wires), and opening the door doesn't set off the alarm.
Here are the wiring charts for my 2005 wrangler
2005 Wrangler Alarm Wiring | Wire Colors| |
12volts|red (40A), red (40A)| + |ignition harness
Starter|pink/orange| + |ignition harness
Second Starter| N/A
Ignition| pink/lt. green| + |ignition harness
Second Ignition| N/A
Third Ignition| N/A
Accessory| pink/yellow (14 AWG) | + |ignition harness
Second Accessory| pnk/yel(16AWG), pnk/yel(12AWG) | + |ignition harness
Keysense |purple/tan | - |ignition harness or cluster
Power Lock| N/A
Power Unlock| N/A
Lock Motor| N/A
Unlock Motor| N/A
Parking Lights+ |white/yellow | + | headlight switch or driver kick
|purple (D), purple/yellow (P) | - |driver kick or cluster
Dome Supervision |yellow/orange | - |underdash light or cluster
Trunk/Hatch Pin| N/A
Hood Pin| N/A
Trunk/Hatch Release| N/A
Power Sliding Door| N/A
Factory Alarm Arm| N/A
Factory Alarm Disarm| N/A
Disarm No Unlock| N/A
Tachometer| NOT brown or pink/gray | ac |ign. coil pack or any fuel injector
Wait to start| N/A
Brake Wire| white/tan | + |brake pedal switch or driver kick
Parking Brake| gray/black | - |parking brake switch or driver kick
Horn Trigger| red/yellow | - |horn switch or driver kick
Memory Seat 1| N/A
Memory Seat 2| N/A
Memory Seat 3| N/A
a + wire
a - wire
Second Starter| N/A
Third Ignition| N/A
Power Lock| N/A
Power Unlock| N/A
Lock Motor| N/A
Unlock Motor| N/A
Hood Pin| N/A
Wait to start| N/A
Memory Seat 1| N/A
Memory Seat 2| N/A
Memory Seat 3| N/A
