Did you mean the flasher?, it's on the junction block. It's a combination flasher module that also controls the hazard lamps.
COMBINATION FLASHER
[SIZE=+1]WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS, Refer to PASSIVE RESTRAINT SYSTEMS BEFORE ATTEMPTING STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY. [/SIZE]
Disconnect and isolate the battery negative cable.
Remove the fuse access panel by unsnapping it from the right cowl side trim panel.
