Vacume Line Help Please
RedWrang
I have an 87 with an inline 258 carburated 6cyl. I replaced the exhaust manifold gasket and intake gasket. All is back perfect except 2 vacume lines. Can someone please tell me where they go, its the line comming from the distributor where does it go. The other is if your looking at the engine from the front its on the left side of the carb about middle way and kinda at the bottom. What hose hooks to it. Any help will be greatly appreciated. Thanks[addsig]
1048837
See if this helps Rob
Look under fuel systems and emmisions
http://4wheeldrive.about.com/gi/dynamic/offsite.htm?site=http%3A%2F%2Fwww.ifsja.org%2Ftech%2Findex.shtml[addsig]
1048862
The diagram is perfect except it does not show the fitting on the carburetor. Ill re look I may be missing it. I did see the one going to the distributor.[addsig]
