vacume lines
I never did like those either, on BOTH YJ's I had I pulled them off and installed 4x4 posi loc instead.
This diagram should be accurate for your YJ, but not newer YJ's. Newer YJ's moved the 4wd light switch to the axle and did away with the vacuum line from the axle disconnect to the switch on the firewall.
