dingus
Active member
1042947
ok... my jeep is still overheating, now after replacing the thermostat. i'm gonna pull out the radiator thursday to check that out, but i'm wondering about the waterpump too... when the car is idling, it overheats. when its moving, it doesn't. when the AC selector is anywhere but "off" (the one with like, AC HIGH, normal, bi-lev, heat, defrost) it tends to make a squealing noise from the front. i don't think its the serpentine belt kuz it was just replaced. the hot-cold selector has no effect on this.
i tried running some "radiator stop-leak" which i've heard mixed opinions about, and i'm gonna take the radiator out and flush all the crap out of it, hopefully it just needs a good cleaning. also, when i look down the overflow tank, i can see the particles of this stop leak crap just floating around... i don't like that at all.
i'm now running a 180 degree thermostat, if that helps. do you think my waterpump bearing is going bad? [addsig]
