webber caburetor
quikfix
Hi just installed a weber caburetor on my yj 89 and it has a flooding problem can anyone help stop this fault:cry:
What kind of flooding problems. overflowing??= stuck float, try tapping on the float bowl a few times with a screw driver or wrench. check fuel presure, maybe too much pushing past the seats in the carb. carb not adjusted right.
Did you go with a 38 DGES synro or a 32/36? Regardless, lets start with the basics. Did you install a pressure regulator set for 4psi? Have you removed the fuel return line? You can still use a fuel return, but you will need a quality PRV or three way regulator like the one available for Holley. Are the vacuum lines properly connected?
