what do u do when ur bored of ur jeep?
cali_92
just put the lift on... have no money, it needs everything else done to it.
whats close to free i can do with my jeep besides wheeling(<gas)
Increasing fuel capacity from 15gal to 20gal is free if you have the 4cyl engine.
pull the carpet out.
wash / wax it (or rub mud on it depending on taste)
lube all the grease fittings
rotate the tires
new plugs (not free but cheap)
Mines so darn pretty,I just sit there and looks at it.
Making the jeep lighter is always good. Remove all the additives from the oil and gas.
Seriously I recall reading a post where some things were offered. One was inexpensive, and debatable. That was covering the inside of the rear signal with reflective tape. It didn’t make it brighter but did diffuse the light so the full lens lit when in reverse or signaling. At least that’s my results.
What is the mod for the stock fog lights mentioned in that post on JeepForum?? The link doesn't work and I'm curious as to what it is. Anybody know?
It is removing one of the pins on the stock relay so that the fog lights stay on when you turn on your high beams.
