1041181
...Asides from everything being thrown up onto the roof
My first post here and from what I've seen, its a very cool little community of jeepers.
I have a 93 Cherokee that i recently rolled over. I hydroplaned on an uphill road, when the back end swung out from behind me, I did a 180, crossed over the double yellow, and continued to slowly slide sideways towards the embankment. My back passenger side tire fell off the road, and momentum kept me going into the ditch. End result was I was upsidedown about 160 degrees, my passenger side was resting against the side of the embankment and two small tree stumps, and the driver side got a small tree to the windshield A-pillar. Luckily, the roof never touched the ground as i was wedged. I had about $3000 worth of body damage, most of which went to a new paint job, the rest was a new hood, front right fender, back passenger window (2-door style), windshield, and trailing arms.
I lost about 4 qts. of transmission fluid which caused some hard shifts in the beginning. A month later that seems to have gone. i have also been loosing a little oil, possibly to spillage or blow-by from the filler cap, but still investigating. Last week I had the distributor cap replaced and crankshaft position sensor replaced because the truck simply wouldn't start. It stalled twice before at idle, but nothing further since the repair.
Anyways, is there anything else I should look out for, inspect, or replace, due to the rollover? Anyone else have good/bad outcome from a rollover?
-Rob [addsig]
-Rob [addsig]
