Ragtopman
Here I go again with a rediculous question. Someone told me there are certain bolts on the transmission that if you touch them your screwd. The transmission for my 91 YJ 4.0l that has taken all month to be rebuilt is going in tomarrow. I picked up the pennzoil as informed but where does it go in and where do you check it? My Haynes manual which I have come to feel is worth spank says that the drain is on the bottom and the check is near the passenger side top. Well my trans has one at the passenger side bottom that I assume is the drain and another on the drivers side near the middle is this the check. also can I just pour the stuff in through the shifter hole since the shifter will go in last. lastly and most importantly which is the check bolt.
