Will a 2" lift clear 33"s on a YJ?
BillT
Can I clear 33x12.50s on a YJ with a 2 inch suspension lift?
I'm a pretty relaxed driver but am I going to see any real performance difference coming from 31s?
Before yall get mad, I swear I used the search bar.
If you plan on going off road you'll need at least a 3" lift. I'd go with 4". You will notice a slight loss of power due to the size increase of the tires effectively raising your gear ratio.
BillT said:
I'm pretty sure my offroading most of yall would consider driving down a dirt road.
Not really. I'm thinking off roading that will cause your suspension to flex and stuff those 33's into your fender wells.
I concur. 33's will not stay clear of the fender well with a 2" lift. You will find yourself rubbing at some point, regardless of the trail difficulty level.
I also agree that a 2" lift is not appropriate for most any offloading. You are gonna drag. If you're going to install one might as well get a 4" and be done with it. You'll look sweet and be able to clear obstacles on the trails
I have a 4.5" lift with 33" mtr's and I rub the fender flares when offroading all of the time. Even when I take them off eventually, i will prob have to trim at least the rear fenders.
