Willy's doors
dbjack
I'm wondering if doors off a 1963 wagon will fit my 1955 wagon. Don't want to drive 50 miles to find out so looking for a little help. Thanks
I think so, the body lines should also line up great, I am just not positive that the latching mechanism is the same, but this should be interchangable between the two.
Looking at my part compatibility book I bought from kaiser willys the door it self is the same but there were 2 different window frame styles one was almost straight/slight tilt and the other was tilted a little more depending on the windshield posts
but there not to hard to change out
they used these doors on both the pick up and wagon
i recommend you pick up one of these books they are a big help when building a old jeep so you know the right name for certain parts and if maybe your missing something but not sure what .
was the best 24.99 I ever spent
it even references eng/trans swaps ,axle ect
it tells you straight up if it will fit or not
Do they make those books for other models. That sounds extremely helpful, and exactly what I need. If so, where do you get it?
