window lever
jeepmaster
how do i remove the manual window lever on my cherokee? i need to get the door panel off so i can put in new speakers.... thanks[addsig]
1065286
pull hard on the circular part of it, be carefull when taking off the doorpanel for that clip up on top of the panel cause that vinyl stuf will tear if that plastic clip breaks
1065295
i usually prefer to use a screwdriver to pry off the little metal clippy thinger on the shaft of the window crank. then it just slides off and you're not forcing anything.[addsig]
1065322
i dont have a circular clip, i just carefully yanked them and they came off. thanks[addsig]
1065478
i met ted nugent at a bowhunters convention in the hotel i work in, he gave me a ted nugent guitar pick. it was awesome[addsig]
